but now it’s requiring Erp.Proxy.BO.InvTransferImpl.GetTransferRecord(Part, System.Guid, PCID, UOM, out bool, Erp.BO.InvTransferDataSet).
I’ve got most of it worked out but we were actually using this method to get the dataset in our customization so I’m running into a wall getting the dataset required by this method. Any advice would be greatly appreciated.
Thanks for the quick response. I’m not sure I follow though. Do you mean something like Erp.BO.InvTransferDataSet itDS = new Erp.BO.InvTransferDataSet()? If you have a moment could you elaborate?
I got this working some time ago so a little rusty on the problems I had to get it working. Happened to be amending the code for another purpose when spotted your call.
I am making a REST call from php so I setup the post fields as follows
iPartNum to the Part Number
sysRowID 00000000-0000-0000-0000-000000000000
iPCID blank
uomCode to the Unit of Measure for the Part above
“ds”: {} for the dataset
Ahhh. Thanks again Mark. Unfortunately this is not a REST call and when I try to pass the dataset from the code above into the method I get “Cannot implicitly convert type ‘void’ to ‘Erp.BO.InvTransferDataSet’”
Time to get back to hacking at it. This one issue on 2 different forms is the last of customization fixes I need to make for our upgrade.
