When running this report we get the following errors:
Epicor10LIVE: A communication error occurred trying to run task ID 172293 for agent SystemTaskAgent on the application server (User: jschmenk, Task Description: Inventory WIP Reconciliation Report). If this continues to happen investigate if you need to increase the receive and send timeouts in your web.config.
Error Detail:
The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was ‘23:59:59.9980000’.
Epicor10LIVE: A communication error occurred trying to run task ID 172315 for agent SystemTaskAgent on the application server (User: jschmenk, Task Description: Inventory WIP Reconciliation Report). If this continues to happen investigate if you need to increase the receive and send timeouts in your web.config.
Error Detail:
The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error.
If it does manage to complete it takes at least an hour. All other reports work fine, and i have tried re-deploying this report. Any idea on how to speed this up? We are on 10.1.500.11
