Integrated table workbench
Hi Folks, We are in process of addressing issues flagged by the integrated table workbench. Is there a guide or something to help on this process? Once an issue is fixed in the application, does a refresh cause the record to disappear or is this something we need to delete it manually once a fix is done?
Thank you!
Once you fix the error in the data, you can go to Actions->Validate. If the problem is fixed, the record gets processed and disappears from the queue. Of course, the data is still on the screen so any screen changes will result in an error. I usually clear the screen and then search for the next issue.
Thank you Doug for the reply!
Alex
