Sorry for not responding to this e-mail. I Was offered a lot of assistance over the Sunday (Panic mode to be live the next day). I received some support from Ben Nixon on the Sunday, and magically things worked fine. The final analysis on the issue was as simple as the Target Directory on the properties of my Vantage Admin icon included "~", which of course made nothing work. Ben identified this and I was off to the races.
Thanks to all for your assistance last weekend. We were live on Monday morning. I've never been paged so many time in my career. Still struggling with a few issues, but for the most part things have settled down. Lot's to learn....
Bob
Sent: Sunday, June 7, 2009 4:42:23 PM
Subject: RE: [Vantage] Re: Installation Help 8.03 ANYONE!!
The PF files never get installed to the client803 folder, the icons that are
created by the installation program are created WRONG and need the correct paths
manually created to point to the mfgsys803\server\ config folder.
The admin and schema tools can only be used on the server, not any other PC
unless the whole admin tool set is done, and even then the PF files need lots of
editing.
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Molson
Sent: Sunday, June 07, 2009 11:50 AM
To: vantage@yahoogroups .com
Subject: Re: [Vantage] Re: Installation Help 8.03 ANYONE!!
Guys, if you recall from the thread this morning that I did a fresh client
install yesterday. I took a look at he mfgsys.pf did not get installed into the
C:\client803\ client\config folder.
I will place a copy of it in this folder as well as the Epicor/Mfgsys803/
server/config/ client config folder
____________ _________ _________ __
Sent: Sunday, June 7, 2009 11:46:35 AM
Yes you can copy into the client config folder
Bob
editing.
Molson
Date: Sunday, June 7, 2009, 11:35 AM
Mark, it is in the config folder as you indicate below, but it is NOT in the
client config folder. Are they both the same? Can I copy from one to the other?
Sent: Sunday, June 7, 2009 11:24:40 AM
Yes it should be in the client directory under Epicor/Mfgsys803/ server/config
and also under Epicor/Mfgsys803/ server/config/ client config
Date: Sunday, June 7, 2009, 11:03 AM
Mark, I am logged in as Administrator. Ben Nixon set the server up with us 2
years ago as we bought it specifically for Vantage. I am changing the security
on the C: Drive as it has what appears to be special permissions for
administrative reasons. I am going to re-apply.
The issue still seems to be with the mfgsys.pf file. Is it suppose to be in the
c:\client803 directory? It isn't. I logged into another computer yesterday, did
a fresh client install and added the progress client as well. (This is needed so
I can perform a schema change and access the administrative functions of
Vantage). It still gave me the cannot open mfgsys.pf error
Sent: Sunday, June 7, 2009 10:53:03 AM
Are you an administrator on your server? Is there sharing/security on the folder
you are trying to delete and do you have rights to that folder?
Date: Sunday, June 7, 2009, 10:44 AM
One quick question. My server will not let me delete the C:\client Directory.
Says it is protected or something along those lines.. Even after uninstalling
the Manufacturing client, I can't get rid of it. As a result I am not able to
re-install the manufacturing client into the C;\client directory. I have to make
up a new directory to proceed.
Thoughts?
Bob
From: alldoneprojects <ramsey@alldonecomp u ters.com>
Sent: Sunday, June 7, 2009 10:39:29 AM
Subject: [Vantage] Re: Installation Help 8.03 ANYONE!!
There are some registry keys also that you should delete for uninstall of
8.3.4x. Anything at:
HKCU\Software\ PSC\
also
HKLM\Software\ PSC\
These had me banging my head for hours because multiple reinstalls wouldn't work
before.
-Ramsey
--- In vantage@yahoogroups .com, "bw2868bond" <bwalker@... > wrote:
> As long as you have the 8.00.812 converted db safely backed up and saved, then
yes. I would uninstall 8.03 and 8.00, 10.1b and 10.1a delete the epicor
directories and start fresh - I also would run the schema change and conversions
right from the server
> but then, that is just me....
> I feel your pain - I converted sharepoint 2001 document library to MOSS 2007 2
weekends ago - good thing it was a 3 day weekend
> --- In vantage@yahoogroups .com, Molson <an_ex_molson@ > wrote:
> > Just a quick opinion on your part. What if I uninstall Vantage 8.03 (Both
Client and server) Re-install Vantage 8.03.400 and then the .407 Patch. The do
the prorest again?
> > I am down to the short end of the rope. I hate the thought of all of our
users coming in on Monday to Vantage 6.10 AGAIN
> > Bob
> > From: bw2868bond <bwalker@>
> > Sent: Saturday, June 6, 2009 6:09:29 PM
> > That is certainly strange.
> > I would make sure the correct version of open edge admin service is running
> > 8.00..812 is 10.1a and
> > 8.03.40x is 10.1b
> > none of the pf files should have been changed since test conversion - nor
any of the Vantage software.... ..
> > --- In vantage@yahoogroups .com, Molson <an_ex_molson@ ...> wrote:
> > > yes
> > > From: bw2868bond <bwalker@ >
> > > Sent: Saturday, June 6, 2009 5:59:36 PM
> > > Same machine that did test conversions?
> > > > If there are any technical people out there working today I could really
really use some help. I have just done a dump and load of my 6.10 data base with
success. I have installed and converted to 8.00.812
> > > > The kicker is as follows:
> > > > I performed a test conversion a couple of weeks ago (again with
success), to get me to 8.03.407
> > > > Today after backing up my 8.00..812 data and doing the prorest I am not
able to launch my change schema client. I get an error. I tried uninstalling the
client and re-installing, but it doesn't let me use the c:\client directory, so
I create a different directory. I get the same error. It has to do witk finding
the mfgsys.pf (unable to open)
> > > > ANY HELP would be appreciated as I started yesterday and have been here
at the office for too many hours. I am suppose to be live on Monday morning. I
don't have weekend support with Epicor, but regardless, there was no answer....
> > > > Bob Goss
> > > > BC Instruments
> > > > (905) 939-7323 (ext.332)
> > > > (289)221-3738 (CELL PHONE)
> > > > ____________ _________ _________ _________ _________ _________ _
> > > > Connect with friends from any web browser - no download required. Try
the new Yahoo! Canada Messenger for the Web BETA at http://ca.messenger
.yahoo.com/ webmessengerprom o.php
> > > > [Non-text portions of this message have been removed]
> > > Yahoo! Canada Toolbar: Search from anywhere on the web, and bookmark your
favourite sites. Download it now
> > > http://ca.toolbar. yahoo.com.
> > The new Internet ExplorerR 8 - Faster, safer, easier. Optimized for Yahoo!
Get it Now for Free! at http://downloads. yahoo.com/ ca/internetexplo rer/
Ask a question on any topic and get answers from real people. Go to Yahoo!
Answers and share what you know at http://ca.answers. yahoo.com
http://ca..toolbar. yahoo.com.
Looking for the perfect gift? Give the gift of Flickr!
http://www.flickr. com/gift/
http://groups. yahoo.com/ group/vantage/ files/.
http://groups. yahoo.com/ group/vantage/ messages
http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
__________________________________________________________________
Make your browsing faster, safer, and easier with the new Internet Explorer® 8. Optimized for Yahoo! Get it Now for Free! at http://downloads.yahoo.com/ca/internetexplorer/
