Install Vantage SQL error
If your DB is not running, then that's why you are getting that error.
The DB needs to be running in order to access the Admin tools.
Also, if you just installed, then you want to double check your Target line
in the shortcut, the default target line that was created by the
installation process is wrong, the location of the -pf and -ininame need to
be updated to the correct locations.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, December 11, 2008 9:35 AM
Subject: [Vantage] Install Vantage SQL error
>I installed Vantage803.400 SQL. Everything goes welll.No Patch yet.
> But when I open Admin tools.There is a warning message:"Cannot find or
> open file d:\epicor\train803\db\mfgtrainsh.db",errno=2.(43)
> and my db is not running
> I have already install TrainDB.
> Is there anything wrong with my installation?
> Any advise?
> Many thanks.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Any advise?
Many thanks.
