Install new test server - how to update prod DB for testing?
Folks,
I am setting up a fresh server for testing 10.2.100.8. I want to test with our production data but am not sure what is the best way to pull the data from the production system (10.1.400.32) into the new test server.
Can i do a fresh install of 10.2.100 on the test server, restore the Live db into that server then will the db be updated when i run the client for the first time???
Cheers
Brett
You’ll run the Update / Upgrade DB Process in Admin Console on the DB after the restore.
You are doing a hybrid of a new install and upgrade, so you’ll need two guides
NIG (new install guide): http://patches.epicor.com/Epicor%20ERP/10.2.100/Epicor10_NewInstallGuide_102100.pdf
UG(upgrade guide): http://patches.epicor.com/Epicor%20ERP/10.2.100/Epicor10_ReleaseUpgradeGuide_10xto102100x.pdf
From a high-level, after you restore your DB, you’ll
  1. Install 10.2.100 then 10.2.100.8 on your new testing server (chapter 2 through 3.3 NIG)
  2. Register the existing DB in the EAC as a 10.2.100 db. (chapter 4.1 NIG then instead of 4.2 NIG right-click on your SQL instance and register existing database)
  3. Upgrade the DB to 10.2.100.x schema level. (chapter 2.6 UG)
  4. Create a new appserver (chapter 5 NIG–NOTE: PLEASE remember to complete 5.2 or you’ll have issues later on)
  5. Log into the client and complete various actions like DB conversions (chapter 3.1.1 through 3.1.9 UG)
