Anyone have a way to add a custom field to the Inspection Processing form? All the bindings are views, doesn’t seem like it is possible?
sure it is, it writes to the erp.nonconf table, you’d have to create a UD field on that table, regen your data model, cycle app server and you should see it in the various views. You may have to carry it there to other places. I never had a need to hold it in tables other than nonconf unless i was grabbing it at the DMR processing portion, but that’s easy enough.
