Hi All
Inpsection Attribute fields have limitation on number available.
For instance InspResultsNum has only 200 attributes available.
Does anyone know how to increase this amount?
Many thanks
Carla
Hi All
Many thanks
Carla
You could use a UD Table to add more. I would recommend trying to create the fields as generic as possible so that they can be reused. If you keep the fields generic, you can rename them when creating the Specification.
