Cathy
(Cathy Bennett)
March 16, 2018, 4:34pm
1
Since the Customer Price list does not have an Audit/Charge log, I am attempting to create one via BPM.
I search this forum for into -
It one BPM it has:
/* Find current record in dataset */
using (var txScope = IceContext.CreateDefaultTransactionScope())
The other I looked at has:
using(var UD02svc = Ice.Assemblies.ServiceRenderer.GetService(Db))
which is correct - also how is var defined?
Any help would be appreciated.
jgiese.wci
(Joshua Giese)
March 16, 2018, 4:37pm
2
var UD02svc = Ice.Assemblies.ServiceRenderer.GetService(Db);
string custNum = ctr.CustNum.ToString();
UD02Tableset ds = new UD02Tableset();
var udRow = (from ud02 in Db.UD02 where ud02.Company == ctr.Company && ud02.Key1 == table && ud02.Key2 == action && ud02.Key3 == custNum select ud02).FirstOrDefault();
if (udRow == null)
UD02svc.GetaNewUD02(ref ds);
ds.UD02[0].Key1 = table;
ds.UD02[0].Key2 = action;
ds.UD02[0].Key3 = custNum;
UD02svc.Update(ref ds);
@T11 this is what you were looking for as well. I have also had success adding ChangeLog records the native way. I did this for Employee Entry
Cathy
(Cathy Bennett)
March 17, 2018, 12:33am
4
I must be doing something wrong - under actions in the BPM - I usually choose execute ABL code - it doesn’t like this -
There is a nice example here.
Cathy
(Cathy Bennett)
March 20, 2018, 9:56pm
6
I am definitely not understanding.
I created a Data Directive on PLParkBrk where the rowmod = A, U and D.
What is the syntax to access table UD02.
rbucek
(Rob Bucek)
March 20, 2018, 11:16pm
7
Cathy,
You posted this question in E9, is that the version you are looking to do this BPM in? I see a lot of people throwing C# at you (shame on you people - you know who you are lol) you should be looking for ABL or 4GL examples of which there should be more than a few on here.
gpayne
(Greg Payne)
March 20, 2018, 11:20pm
8
here is the ABL to create a UD02
Create UD02.
Assign UD02.key1 = key1
UD02.key2 = ""
UD02.key3 = ""
UD02.key4 = ""
UD02.key5 = ""
UD02.Company = cur-comp.
Assign UD02.ShortChar01 = ""
UD02.Number01 = 0.0 .
Release UD02.
rbucek
(Rob Bucek)
March 20, 2018, 11:37pm
9
I was waiting for you to step in @gpayne
gpayne
(Greg Payne)
March 20, 2018, 11:59pm
10
@rbucek Yep I feel like the last of the ABL coders. Hopefully after Insights I will get a chance to jump into E10 coding.
rbucek
(Rob Bucek)
March 21, 2018, 12:26am
11
Awesome, we’re all here for you if you need us. You certainly have provided a ton of guidance for us over the years in ABL.
@gpayne
I attempted to use your code to create a E9 BPM. The BPM validates. It triggers. I have a notification message to tell me so. But then it never created the UD record. What could be preventing this from working?
gpayne
(Greg Payne)
April 10, 2020, 8:50pm
13
@Carl_Gansen If you can post your code we can look. At least one key has to have a value and all 5 have to be set.
Do you have your appserver in verbose so you can look for messages there?
I figured it out. I had another piece of code that was throwing a hidden error and preventing your code from running.
