Indenting in BPM code
I feel like I’m losing my mind, but is there no consistency in the auto-indenting within the BPM code block node? I swear that some and tabs and some are spaces. If we could get drop lines in here, I’d would be so happy
Both tabs & spaces? I haven’t noticed this but wouldn’t be surprised if you’re correct.
I’m reminded of a scene from the show Silicon Valley, tabs vs. spaces discussed in more detail here…
I know on some of my more obsessive days I am guilty of wasting time cleaning up indentation.
Best show on TV now.
Said no Python programmer ever…
While on the topic of indenting…
Does an open brace belong at the end of the line like
if(value){
Or by itself and indented like
if(value)
And where does the closing brace belong? Even with start of the line that created the block
if(value){
   // do stuff
Or indented with the lines of the block?
if(value){
   // do stuff
If(value){
…// Do stuff
Or
If(value)
…// Do stuff
…// My personal preference
If there is only a single statement this is also acceptable…
If(value){ /* Do Stuff */ }
If you have visual studio, the code can be format using Format Document.
But make sure you set the Tab and Indent size correctly in the Options, also, I normally use Insert spaces rather than tab.
If (is it readable == true)
    move on
else
  if (is it a turd == true)
      Don't bother, you can't polish a turd
  else
      Take the rest of the day to make sure the next person can understand, what in your mind, appears to be a blazing piece of technical genius, using your favorite code beautifier.
