What would a baq for this look like? Starting from the top level and going till the bottom about 3-4 steps
Hit F1 (Help) in Epicor BAQ and that exact example is spelled out for you there.
When I do that nothing pops up
Do you have a screenshot of the example you could share?
That menu doesn’t popup on my screen for some reason. Could you share the entire example instructions?
No I cannot that’s Epicor’s Property. If you just open the Help and Type Create CTE you will get it. I cannot share Epicor’s Copyrighted Material publicly here.
When I click help it says server error (403 - forbidden: access is denied)
Since you are in the Cloud I’d contact Epicor about your help being broken
If you can’t get help to work sign into your EpicWeb account and download the EpicorICETools_UserGuide. It has the same information.
Is there a way to filter only orders that are open to this query specifically? As well as calculate the qty of each material that is needed at a top level combining each order?
