I would also like a copy please.
llowney@...<mailto:llowney@...>
Thank you very much.
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Sent: February-28-13 3:58 PM
Subject: Re: [Vantage] Re: Incorrect conversion factor for UOM
Can I get a copy of these as well. Thank you
jrestivo@...<mailto:jrestivo%40cnpkg.com>
From: "janjanowiak@...<mailto:janjanowiak%40sbcglobal.net>" janjanowiak@...<mailto:janjanowiak%40sbcglobal.net>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Tuesday, January 22, 2013 2:30 PM
mailto:JanJanowiak%40powergreatlakes.com
Janice Janowiak
Linda
Janice Janowiak
On Jan 22, 2013, at 12:55 PM, "Richard Sirow" mailto:rick%40iccparts.com> wrote:
> Yes.
> Anyone who wants instructions, please e-mail me & I will respond off-list
> Richard Sirow, President, Independent Components Corp.
> From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of
> jgiese1988
> Sent: Tuesday, January 22, 2013 1:00 PM
> To: mailto:vantage%40yahoogroups.com
> Subject: [Vantage] Re: Incorrect conversion factor for UOM
> Do tell... :) version 9.05.x?
> --- In mailto:vantage%40yahoogroups.com , "Richard
> Sirow" wrote:
> > Stan,
> > If this is a Part Specific UOM Conversion I can give you instructions -
> > there is a hidden override field that can be used.
> > Rick Sirow
> [mailto:mailto:vantage%40yahoogroups.com ] On
> Behalf Of
> > stanchmura
> > Sent: Tuesday, January 22, 2013 11:51 AM
> > Subject: [Vantage] Incorrect conversion factor for UOM
> > Unfortunately I have entered an incorrect conversion factor for UOM.
> (Inches
> > to feet is 1 and should be 12). Since there are transactions on the parts
> > assigned to it, it now cannot be changed. And I can't set up a new
> (correct)
> > one and reassign it to the affected parts for the same reason
> > (transactions). I have contacted Epicor for a solution (likely some kind
> of
> > custom programming) but they are sluggish to reply and I expect a high
> cost.
> > If any one encountered an entry error like this, I would be very
> interested
> > if and how it was solved. Perhaps a workaround I've not thought of? (all
> new
> > part numbers and a new UOM was considered but this affects about 900 part
> > numbers.)
> > Thanks
> > Stan
