THANKS.
--- In vantage@yahoogroups.com, "Rebecca Schmuck" <rschmuck@p...>
wrote:
>did work for
> We had a similar situation; and the following steps from Epicor
> us (however, we did test it in Training first!):Behalf Of
> Issue:
> AP Advance
> Billing Invoice done on Purchase Order with multiple lines.
> The
> entire Advance Billing balance was posted to Line 1.
> How do
> I move that balance to Line 2 or Line 3 etc?
> Resolution:
> Create
> an Advance Billing Debit Memo for Purchase Order Line 1.
> (Make
> sure Line > Add Advance Billing is chosen when doing the Debit
> Memo)
> The Value of the Advance Billing Debit Memo should equal
> the amount that needs to be moved to other lines.
> Post.
> You
> can now create Advance Billing Invoice for the proper lines
> of the Purchase Order.
> Post.
> Now apply the Debit Memo to the
> new Advance Billing Invoice(s) OR go to Accounts Payable > General
> Operations > Adjustment and Adjust the Advance Billing Debit
> Memo and the new Advance Billing Invoices to zero.
> You have
> now properly moved the dollars from Line 1 of the Purchase Order
> to the other Lines of the Purchase Order.
> This will be shown
> in the PO Tracker.
> Now enter Receipt for those Lines.
> Now
> create Receipt Billing Invoice for those Lines.
> The "less advance"
> amount will flow to the lines.
> NOTE:
> If you have already
> done the Receipt Billing Invoice for Line 2 or Line 3 and Posted
> do the following....
> Create an Advance Billing Debit Memo for
> Memo should equal the amount that needs to be moved to other
> lines.
> Post.
> Apply the Debit Memo to the Receipt Billing Invoices
> in order to Reduce their values OR go to Accounts Payable >
> General Operations > Adjustment and Adjust the Debit Memo down
> and Adjust the Receipt Billing Invoices down by that same amount.
> Good luck!
> Rebecca
> P-K Tool
> -----Original Message-----
> brychanwilliamsinvoice. I
> Sent: Thursday, January 05, 2006 9:07 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Incorrect AP Invoice
> Hi,
> I have created an advance billing AP invoice and have posted the
> would like to clear the invoice by adding a debit memo.invoice and
> Then I would added a unreceived ap invoice and then the receipt.
> Is this the correct way?
> Secondly,
> I made a bigger mistake... I have created an advanced billing
> posted and received against the PO. I need to reverse this somehow, But I
> am not sure how. Any advice ? Many thanksmust have
> already linked your email address to a yahoo id to enable access. )Builder and
> Yahoo! Groups Links
