Inactive Parts Blank Title 106986
Sounds like a UD Checkbox at the plant level, and some BPM's where you would
normally select those parts (Order Entry, PO Entry) would be the way to go.
Kevin Simon
aman
Sent: Wednesday, January 25, 2012 12:28 PM
Subject: [Vantage] Inactive Parts
Hi,
We are on 9.05 and have come across a situation which I had thought would be
easy to resolve but cant figure out. We operate multi-plants and often have
shared parts i.e parts which are available in two plants. Now we have a
situation where one of the plants does not use the part anymore and I want
to restrict people selecting those parts. It is a valid option in the second
plant.
I cant make the part inactive or change the description to prefix it with
OBSOLETE etc as it is still active in plant 2. I cant delete these parts
from Plant 1 as there are transactions.
Do I have any neat option other than to put a BPM which will only
retrospectively bring up an error if they select that part?
Regards
Aman
Hi,
We are on 9.05 and have come across a situation which I had thought would be easy to resolve but cant figure out. We operate multi-plants and often have shared parts i.e parts which are available in two plants. Now we have a situation where one of the plants does not use the part anymore and I want to restrict people selecting those parts. It is a valid option in the second plant.
I cant make the part inactive or change the description to prefix it with OBSOLETE etc as it is still active in plant 2. I cant delete these parts from Plant 1 as there are transactions.
Do I have any neat option other than to put a BPM which will only retrospectively bring up an error if they select that part?
Regards
Aman
