Trying to set up a data directive that pushes the value from a BAQ calculated field into a UD field on the SugPoDtl table. Admittedly, I am not too well versed in LINQ, so here’s the code and what results when I check the syntax:
What am I missing here? Any suggestions are welcome, thanks!
josecgomez
(Jose C Gomez)
October 27, 2021, 3:03pm
2
Executing a BAQ on a Data Directive is a sure fire way to bring your system to a grinding halt.
You are already in a BPM (server side) so you should be able to just lookup the value using LINQ from wherever it comes from and copy it around.
HLalumiere
(Hugo Lalumiere)
October 27, 2021, 3:50pm
3
Performance issues aside, the dataset doesn’t contain rows, it contains tables!
Should be dsResults.Tables[0].Rows[0]
@HLalumiere Thanks for the tip; when I tweaked it like this:
and checked the syntax, I got no errors.
Now attempting to generate PO suggestions, and wait…
What are some good resources on learning LINQ, other than Microsoft’s own documentation?
