You load the customization into the customization maintenance window. You don't
run it. You should not open up MES in order to do this.
Sent: Mon, 9 May, 2011 15:16:47
Subject: [Vantage] Re: Importing customizations
So far, so good. but how do I "verify" after I load the base customization? Is
there a menu command?
I'm going to MES developer, loading the base, then what should I do?
--- In vantage@yahoogroups.com, Mark Kamsika <m.kamsika@...> wrote:
> This is what I did. Switched to developer mode. Select customization
> maintenance. Select the base for for customization maintenance. Load the
> customization and then verify it. You will be prompted to select the base or
> the customization. Select the customized version. It should then verify
> From: CarlH <carl.heeder@...>
> Sent: Sun, 8 May, 2011 13:20:05
> I think I have the same issue but am not clear how you verify one customization
> against another? What am I missing? We're on 8.03.409
> The error I am getting is:
> EpiRadioButton - radSetUp Bound to invalid EpiView
> so now I am suspecting that the GUID of some object changed and is now
> referencing a radio button.
> Any ideas?
> --- In vantage@yahoogroups.com, Mark Kamsika <m.kamsika@> wrote:
> > I have found a work around for this.
> > What I did was to open customization maintenance up in developer mode. I then
> > verified the customization against itself instead of the base.
> > The issue was with GUID ids of the controls
> > From: jckinneman <jckinneman@>
> > Sent: Fri, 6 May, 2011 18:40:12
> > Any chance the environment you developed in is at a different release level
>of
> > Epicor/Vantage? Some releases have been known to change the GUID of
>controls,
> > making the references from one release invalid in another. If so you can
> > usually make some hand edits using Customization Maintenance to fix things.
> > > Hi all,
> > > I am having some trouble importing customisations. The import is presenting
> > > warnings related to missing controls e.g a textbox.
> > > In this particular example I have modified a customisation make to
> > > the Receipt Entry screen in a test environment but upon importing it into
> >live
> > > the extra controls have not appeared on the form and there are warnings
> >present
> > > in the customization maintenance screen
> > > Is there anyway to import this customisation with the controls present and
> > > working.
