Importing BPM from E10 Pilot to E10 Live
I have BPMs that I fixed in E10 Pilot. I exported them and imported them in E10 Live, but they don’t seem to be applied. How do I get them to work as they should after being imported?
I have had this issue before.
Try going into the BPM workflow designer, just move a widget so the designer will allow you to save.
Save, then also save again on the Directives screen, and see if it works.
Thanks worked.
