Import UD Table field properties (via Extended Property Maintenance?)
Good morning,
I am migrating several UD tables from our test database and am hoping I can import the Extended Properties (formats, labels, linked column, etc) that have been set via Extended Property Maintenance. Any help would be appreciated to avoid redoing this all manually. Thanks very much.
Best regards,
Allan
have you tried creating a “SOLUTION” and turn on Solution Tracking? Then you can do the changes, and the solution tracker keeps track of the changes. You can then export the solution, and import it into another DB.
Thanks for the suggestion @timshuwy. I haven’t used Solutions yet but I’ll check it out.
