Import UD Fields
Hi,
Is there a way to export-import UD Fields from an environment to another in Epicor 10.2 and later? For example, from Pilot to Prod (in the same version).
EDIT. I’ll give Paste Insert a try.
Hi
Use Solution Workbench and select zdatatable and build the solution cab file
Thanks Sanjeev,
I’ll give it a try.
@louis.fequet
Please mark the your post as solved please…
I’ve wanted to test it before. But since you’ve asked for it…
Thanks…this helped a lot…moving UD seems easy now
