Import trace log into sql server dbase table
Version 10.X / 202X.Y → 202X.Z
info about importing trace log from on prem server and from users workstations into sql server dbase for admin querying and further research
__Tips:__Looking for anyone who has set up a SSIS or import of the epicor trace log XML file into a sql server dbase table, for further querying and investigating issues and such?
__Known Issues:__XML is quite complex from epicor - not able to post up the xml here
Have you tried the Performance diagnostics tool for this? I use it for trace file analyzing.
