Import Lots of Ship To Addresses
Hi Everyone!
I am getting ready to setup a new customer that has up to 100 unique ship-to addresses. Is there any easy way to load in multiple ship-to addresses for a single customer?
I do not have the DMT, and I do not want to enter them manually one-by-one.
I will try building out my own solution using BPMs and UBAQs if there is not already an easy way.
Thanks!
Nate
You should be able to use the “Paste Insert” on a list view to do a bulk load in. Allegedly DMT was originally based on this functionality. The excel/csv file that you copy needs the key columns, and they need to be in the same order as the list grid. I see there’s a Ship To List in customer maintenance you can try it with.
Paste/Insert worked like a charm! I didn’t expect it to be so easy. Thank you!
Good deal!
