If you run your SQL Server in Azure on a VM
…Brent Ozar reporting from the SQLBits 2022 conferece says:
"Anna Hoffman took the stage and announced that the SQL best practices assessment is now available in the Azure portal. It’s like sp_Blitz, but more powerful because it can be scheduled and centralized.
Thanks Mark!
is this for Managed SQL Instance? or a SQL VM on Azure
Specifically SQL running on a VM (IaaS) and not Managed nor Azure SQL The link shows you need an IaaS extension loaded onto the VM.
Got it, I’m setting it up now thanks Mark!!
Thanks for clarifying.
