Idle users
With Progress 9.1D03, Progress has made available a timeout feature.
To implement the feature the following lines must be added to the
Startup registry key on the server. This process applies to all clients
connected to the database.
Where 'n' is the number of minutes after which the user will be
disconnected if there is no activity. Again, this is a server parameter
so all users will be affected by this setting. Activity is defined as
mouse and keyboard activity from client to server.
This ClientTimeOut parameter can be put into the registry of the
following key, by default this key will not exist so will need to be
created.
HKEY_LOCAL_MACHINE\SOFTWARE\PSC\PROGRESS\9.1D\STARTUP
Once you open the Startup Key, from the top select EDIT > NEW > STRING.
The string name is called "ClientTimeOut" in the value field put in how
many minutes till disconnection.
Once the changes have been made you will need to reboot the server for
progress to reread the registry on startup of the Admin Service.
Of Mesick, Todd
Sent: Monday, December 05, 2005 9:43 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] idle users
Anyone have any scripts that kick out idle users after a certain time??
Thanks for your help.
Todd
TECT Proprietary & Confidential. This message, along with any
attachments,
is intended only for the exclusive use of the individual or entity to
which
it is addressed and may contain information that is privileged,
confidential
and exempt from disclosure. If you are not the intended recipient, you
are
hereby notified that any dissemination, distribution, or copying of this
message, or any attachment, is strictly prohibited. If you have
received
this message in error, please notify the original sender immediately by
return email, or by calling 229-228-2600, and delete the message, along
with
any attachments, from your computer.
Yahoo! Groups Links
Todd
TECT Proprietary & Confidential. This message, along with any attachments,
is intended only for the exclusive use of the individual or entity to which
it is addressed and may contain information that is privileged, confidential
and exempt from disclosure. If you are not the intended recipient, you are
message, or any attachment, is strictly prohibited. If you have received
return email, or by calling 229-228-2600, and delete the message, along with
