I want to clear UltraGrid view Data on Clear Command
Dear Team,
I want to clear UltraGrid with tool clear command.
Any one has done it before .
I have updated data in UltraGrid through BAQ , but now I want to clear it with new form .
If I am trying to create new record then existing Grid not getting clear with new PackId.
private void epiButtonC2_Click(object sender, System.EventArgs args)
EpiDataView partdv = ((EpiDataView)(this.oTrans.EpiDataViews[“SubShipD”]));
System.Data.DataRow
Partrow = partdv.CurrentDataRow;
I tried this but not working
myGrid.Rows.Clear();
Is this a grid you created or an existing grid?
Is it bound to a datasource?
Yes , this is Grid which I have created and data load by Button. Working fine , No issue in that but When I go for another new packId then same Grid existed which I have created for previous PacKID.
It would be great , if you can assist , how can I clear grid or remove this Grid view and load fresh for new PackID.
If I clear form then this UltraGid also should be Clear
Set the datasource to null.
That would be great if you can help out with codes
myGrid.DataSource = null;
I used it but not working
Which event I need to select to execute it ?
AfterToolClick, “ClearTool” I think.
You may have to clear the datasource, then refresh the grid.
private void baseToolbarsManager_ToolClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
    if (args.Tool.Key == "ClearTool")
      epiUltraGridC2.DataSource = null;
      epiUltraGridC2.Refresh(); //? Maybe
I tried this too
if (args.Tool.Key == “ClearTool”)
But not working , after clear the form , Grid exits
Message: --------compile errors------------
Error: CS1518 - line 516 (855) - Expected class, delegate, enum, interface, or struct
** Compile Failed. **
