I am trying to add the below code to a cusomization in Time and
Ah, Yes, you are correct it is now working.
Sorry for the confusion on my part on where to place the code.
Thank you for your help on the matter.
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Tuesday, September 3, 2013 2:08 PM
Subject: RE: [Vantage] I am trying to add the below code to a cusomization in Time and Expense Entry.
Â
The script needs to understand where the type is defined. You can spell it out by providing the entire library path. It should work if you replace what you have with Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Marc Livingston
Sent: Tuesday, September 03, 2013 2:22 PM
Subject: Re: [Vantage] I am trying to add the below code to a cusomization in Time and Expense Entry.
I do now know what you mean by prefix Infragistics.Win.UltraWinGrid
From: Joe Englert <englertj@...<mailto:englertj%40biotek.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Tuesday, September 3, 2013 12:43 PM
Try prefixing with Infragistics.Win.UltraWinGrid to get Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Marc Livingston
Sent: Tuesday, September 03, 2013 1:10 PM
Then I get this error:
Error: CS0103 - line 99 (559) - The name 'UltraComboStyle' does not exist in the current context
private void TimeExpenseForm_Load(object sender, EventArgs args)
// Add Event Handler Code
int DropDownList = 1;
int DropDown = 0;
epiComboC1.DropDownStyle = UltraComboStyle.DropDownList;
From: Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com><mailto:tkoch77%40yahoo.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
Sent: Tuesday, September 3, 2013 10:44 AM
If you want a dropdownlist use this.
ucbEpiCustom1.DropDownStyle = UltraComboStyle.DropDownList
From: Marc Livingston <livingstonmarc86@...<mailto:livingstonmarc86%40yahoo.com><mailto:livingstonmarc86%40yahoo.com>>
Sent: Tuesday, September 3, 2013 11:37 AM
I should have added that I am not familiar with VB or C# at all. So I do not actually know what you are talking about.
From: Jose Gomez <jose@...<mailto:jose%40josecgomez.com><mailto:jose%40josecgomez.com>>
To: Vantage <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
Sent: Tuesday, September 3, 2013 8:10 AM
Why don't you use an ultracombo style instead of an arbitrary integer?
http://help.infragistics.com/Help/NetAdvantage/WinForms/2012.2/CLR4.0/html/Infragistics4.Win.UltraWinGrid.v12.2~Infragistics.Win.UltraWinGrid.UltraComboStyle.html
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...<mailto:jose%40josecgomez.com><mailto:jose%40josecgomez.com>
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Tue, Sep 3, 2013 at 8:56 AM, livingstonmarc86 <livingstonmarc86@...<mailto:livingstonmarc86%40yahoo.com><mailto:livingstonmarc86%40yahoo.com>
> wrote:
> I am trying to add the below to a customization I have to limit user entry
> to only what is in the list. I converted this from a VB sample to C# using
> an online converter. I keep getting the following error though. Anyone have
> any ideas?
> int DropDown = 0;
> ucbEpiCustom1.DropDownStyle = DropDownList;
> Error: Error: CS0266 - line 103 (563) - Cannot implicitly convert type
> 'int' to 'Infragistics.Win.UltraWinGrid.UltraComboStyle'. An explicit
> conversion exists (are you missing a cast?)
> Here is the provided VB sample:
> Private Sub PartForm_Load(ByVal sender As object, ByVal args As EventArgs)
> Handles PartForm.Load
> '// Add Event Handler Code
> Dim DropDownList as Integer = 1
> Dim DropDown as Integer = 0
> End Sub
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
I am trying to add the below to a customization I have to limit user entry to only what is in the list. I converted this from a VB sample to C# using an online converter. I keep getting the following error though. Anyone have any ideas?
int DropDown = 0;
Error: Error: CS0266 - line 103 (563) - Cannot implicitly convert type 'int' to 'Infragistics.Win.UltraWinGrid.UltraComboStyle'. An explicit conversion exists (are you missing a cast?)
Private Sub PartForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles PartForm.Load
End Sub
*Jose C Gomez*
*Software Engineer*
E: jose@...
> any ideas?
> int DropDown = 0;
> End Sub
To: Vantage <vantage@yahoogroups.com>
*Jose C Gomez*
*Software Engineer*
E: jose@...
> any ideas?
> int DropDown = 0;
> End Sub
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
*Jose C Gomez*
*Software Engineer*
E: jose@...
> any ideas?
> int DropDown = 0;
> End Sub
On those days (like today) when those horrible "Object" languages are kicking my butt..... I just throw a BPM on it with a "Sorry Charlie" notification if they choose something not allowed.
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Tuesday, September 03, 2013 11:45 AM
From: Marc Livingston <livingstonmarc86@...<mailto:livingstonmarc86%40yahoo.com>>
From: Jose Gomez <jose@...<mailto:jose%40josecgomez.com>>
To: Vantage <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
*Jose C Gomez*
*Software Engineer*
> any ideas?
> int DropDown = 0;
> End Sub
      int DropDown = 0;
    Â
Â
*Jose C Gomez*
*Software Engineer*
E: jose@...
> any ideas?
> int DropDown = 0;
> End Sub
int DropDown = 0;
From: Ted Koch <tkoch77@...<mailto:tkoch77%40yahoo.com>>
*Jose C Gomez*
*Software Engineer*
> any ideas?
> int DropDown = 0;
> End Sub
Is customization development something you will be doing regularly or is
this a one off deal. If you will be doing it regularly I would recommend
getting some practice under your belt. I would recommend some of these
books. This writer by far has the coolest representation of tech education
IMHO at least. http://www.murach.com/books/index.htm
Josh
Marc Livingston
Sent: Tuesday, September 3, 2013 12:10 PM
int DropDown = 0;
From: Ted Koch <tkoch77@... <mailto:tkoch77%40yahoo.com> >
To: "vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> "
<vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
<mailto:livingstonmarc86%40yahoo.com> >
From: Jose Gomez <jose@... <mailto:jose%40josecgomez.com> >
To: Vantage <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
*Jose C Gomez*
*Software Engineer*
E: jose@... <mailto:jose%40josecgomez.com>
> have
> any ideas?
> int DropDown = 0;
> End Sub
Â
int DropDown = 0;
*Jose C Gomez*
*Software Engineer*
> any ideas?
> int DropDown = 0;
> End Sub
int DropDown = 0;
*Jose C Gomez*
*Software Engineer*
> any ideas?
> int DropDown = 0;
> End Sub
