We opened up a site in Mexico and want to be able to change the language to Spanish for MES…is that possible.
If you purchase the Spanish language pack, yes.
Thanks, contacted CAM.
Not even if I install the WIN OS in Spanish?
Also saw in the Config file there is a Culture Code set to ENU…anyone know what codes I can put in there.
Nope. You need the language pack. The Culture Codes determine your decimals, comma, etc. in numbers.
English/US: 1,000.00
German/Germany: 1.000,00
Mark W.
Anyone use Language Packs and can you tell me how they are deployed. I would like to deploy only to certain MES users. Speaking to the CAM already, but they arent usually helpful when it comes to installation and deployment. Quote a nice price tag.
Off the top of my head, you go to:
EpicWeb and download the language purchased
Then go to
System Management | System Maintenance | Language Maintenance
And import the Translations
We set the language by user, so if you have a user assigned for your MES logins, use that user ID for Spanish. That should do it. I haven’t tried it with MES yet but I think it’s the same process.
Mark W.
Thank you all.
Chapter 7 Localization in the EPICOR Customization User Guide has this info.
