Dears, i have a problem, i have this link and variable passing it to the report server
i want to check if the link is correct or no
Private Sub SaveReport(ByVal vORderNum As String, ByVal vGUID As String)
Dim webClient As New System.Net.WebClient()
Dim url As String = "http://e10/reports/report/%Epicor10Test%CustomWork%SalesOrderAcknowledgments%SOForm&rs:Format=PDF&rs:Command=Render&TableGuid=" & vGUID
webClient.UseDefaultCredentials = True
msgbox(url)
'msgbox(vGUID)
'msgbox("hello")
webClient.DownloadFile(url, "c:\temp\" & vORderNum & ".pdf")
End Sub
