I am trying to use List Items of BAQ Combo Box.
It seems to have the function to change Display member to List Items.
It works well in EpiUltra Combo Box
But, it doesn’t work our in BAQ Combo Box
Once I enter the values and save it, then reopen the customization the values are removed from list items
You only need to use a BAQ combo box if your combo box is showing values from a BAQ. If you want to manually enter the list of items, then don’t use the BAQ combo. Use the EpiUltraCombo Box. You can’t use both a BAQ and a list of string items to populate a single combo box. At least, not without some fancy coding.
