Hello,
I haven’t found the thing I’m looking for in the documentation, so I came to ask here. (as always)
I want a grid which hosts a UD table view (let’s say UD04 for example), This grid will be filled with a button click based on a certain criteria (let’s say divide the total quantity of a receipt based on a number entered by the user in another field). The rows which were generated are editable by default (let’s say I can change the quantity in each line), and if I choose to edit a line in the grid, the changes should be reflected on the Database.
I’ve done this so many times in Epicor 10 that I’ve lost count, but I can’t figure it out in Kinetic.
Dealing with grids is frustrating in Kinetic and the documentation is not helpful.
Does anyone know how to do the scenario I’ve proposed? Will I need to create events in Application Studio to make the update happen? What is the right way of adding a UD view into a Grid?
Any help is appreciated.
Kind Regards,
Aamer.
