I want to seeting Epicor PO email and click approve on email.
Please help suggest a solution/method.
You’ve got two options
BPM
– Fire a BPM on approval state changed with HTML body with your links and PO information for approval. -
Automation Studio
– Automated PO Approval (Via Email) - Kinetic 202X - Epicor User Help Forum (epiusers.help)
------Version depending
If you’re wanting a bespoke solution then unfortunately, you will need to consult with one of the forums consultants or speak directly to PS (Professional Services Team) which will direct you to… CSG.
Hope this helps.
for BPM option, Could you share example?
Take a look at this from @Rick_Bird
Snippet from @DeanMiller :
This should get you started.
I have not tested this code and cannot confirm that it will/will not work. It’s a starting basis for you.
Nince>>
and I’m stuck on creating a button for the approver to press in their email and send the value back to the Epicor.
