To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, September 25, 2013 10:08 AM
Subject: RE: [Vantage] How to set ttCallContextBpmData.Checkbox01
Sent: 25 September 2013 14:59
Subject: [Vantage] How to set ttCallContextBpmData.Checkbox01
I currently have a pre-processing BPM on MoveJobItem that pops up a BPM data form that asks to schedule all lower level jobs.
I have created a data directive on JobOper that will automatically reschedule that job with a .p file.
The problem is, when the .p triggers MoveJobItem it also triggers my other BPM to show the form which I don't want. I am trying to set ttCallContextBpmData.CheckBox01 before I call MoveJobItem in the .p file, but not having any luck.
Anyone have any ideas how to accomplish this?
Here is the .p
{Bpm/Bpm.i &OBJECT_NAME="ScheduleEngine"}
{Bpm/MiscCallContext.i}
{bo/ScheduleEngine/ScheduleEngine_ds.i}
define input parameter iCompany as character.
define input parameter iJobNum as character.
define input parameter iReqDate as date.
{&TRY_PRIVATE}
DEFINE VARIABLE morePages AS LOGICAL.
DEFINE VARIABLE hScheduleEngine AS HANDLE.
DEFINE VARIABLE iFinished AS LOGICAL.
DEFINE VARIABLE iWarn AS CHARACTER.
RUN bo\ScheduleEngine\ScheduleEngine.p PERSISTENT SET hScheduleEngine.
IF VALID-HANDLE (hScheduleEngine) THEN
DO:
RUN GetScheduleRecord IN hScheduleEngine ( {&input-output_dataset_ScheduleEngineDataSet}).
FOR EACH ttScheduleEngine WHERE ttScheduleEngine.RowMod = 'A'.
ASSIGN ttScheduleEngine.Company = iCompany.
ASSIGN ttScheduleEngine.JobNum = iJobNum.
ASSIGN ttScheduleEngine.AssemblySeq = 0.
ASSIGN ttScheduleEngine.OprSeq = 0.
ASSIGN ttScheduleEngine.OpDtlSeq = 0.
ASSIGN ttScheduleEngine.StartTime = 0.
ASSIGN ttScheduleEngine.EndDate = iReqDate.
ASSIGN ttScheduleEngine.EndTime = 0.
ASSIGN ttScheduleEngine.WhatIf = false.
ASSIGN ttScheduleEngine.Finite = false.
ASSIGN ttScheduleEngine.SchedTypeCode = 'ja'.
ASSIGN ttScheduleEngine.ScheduleDirection = 'End'.
ASSIGN ttScheduleEngine.SetupComplete = false.
ASSIGN ttScheduleEngine.ProductionComplete = false.
ASSIGN ttScheduleEngine.OverrideMtlCon = true.
ASSIGN ttScheduleEngine.RecalcExpProdYld = false.
ASSIGN ttCallContextBpmData.CheckBox01 = true.
END.
RUN MoveJobItem IN hScheduleEngine ( {&input_dataset_ScheduleEngineDataSet}, output iFinished, output iWarn).
END.
ELSE
DO:
message "Could not create handle to hScheduleEngine.p!".
END.
DELETE OBJECT hScheduleEngine.
{&CATCH_PRIVATE}
-Ted
