Hi,
how to i set the actual output quantity cannot exceed job production quantity with condition that the job number prefix start with ‘P’?
At one site we added a customization to the MES End Activity form.
used the JobOperSearchAdapter to get the RunQty and the PreviousQuantityReported
and then compare the previous + proposed qtys with the run qty
- warning message if less than run qty
- error message if over the run qty
Note they only used the End Activity form, TBD if you are also using Report Qtys button/form.
And… I’m guessing you could do something similar in a BPM instead of a form customization but… have not actually tried it yet.
@john19 This is how we do it in a bpm on end Activity. We have somethnig similar on report quantity.
/* Stopping Over Reporting of Production Quantities */
string Customer = string.Empty;
int oldLaborQty = 0;
Erp.Tables.JobHead JobHead;
Erp.Tables.LaborDtl LaborDtl;
Ice.Diagnostics.Log.WriteEntry("MD Labor Update stop over reporting start");
var orgLaborDtl = (from Old_Row in ttLaborDtl
where Old_Row.Unchanged()
select Old_Row).FirstOrDefault();
if (orgLaborDtl != null)
oldLaborQty = System.Convert.ToInt32(orgLaborDtl.LaborQty);
foreach(var ttLaborDtlRow in ttLaborDtl.Where( ttLaborDtl_Row => ttLaborDtl_Row.Updated() && ttLaborDtl_Row.LaborType == "P" || ttLaborDtl_Row.LaborType == "S"))
//var ttLaborDtlRow = ttLaborDtl_iterator;
// Ice.Diagnostics.Log.WriteEntry($"Type {ttLaborDtlRow.LaborType}");
if(string.Compare(ttLaborDtlRow.LaborType,"P",true)== 0)
// Ice.Diagnostics.Log.WriteEntry($"before joboper job {ttLaborDtlRow.JobNum} asm {ttLaborDtlRow.AssemblySeq} opr {ttLaborDtlRow.OprSeq}");
var jo = Db.JobOper.Where(j => j.Company == CompanyID && j.JobNum == ttLaborDtlRow.JobNum && j.AssemblySeq == ttLaborDtlRow.AssemblySeq && j.OprSeq == ttLaborDtlRow.OprSeq).Select(j=> new {j.QtyCompleted,j.RunQty}).FirstOrDefault();
// Ice.Diagnostics.Log.WriteEntry("after read");
if (jo != null)
// Ice.Diagnostics.Log.WriteEntry($" End Act in JobOper Complete:{jo.QtyCompleted} LaborQ:{ttLaborDtlRow.LaborQty} Total {jo.RunQty} ");
// Ice.Diagnostics.Log.WriteEntry($" oldlabor {oldLaborQty}");
if((jo.QtyCompleted - oldLaborQty) + ttLaborDtlRow.LaborQty > jo.RunQty && ttLaborDtlRow.LaborQty != 0)
throw new Ice.BLException("There are already " + jo.QtyCompleted.ToString("N2") + " complete. The operation required quantity is " +
jo.RunQty.ToString("N2") + ". You entered a quantity of " + ttLaborDtlRow.LaborQty.ToString("N2") + " this will result in over reported quantities.");
ttLaborDtlRow.LaborQty = 0;
// Ice.Diagnostics.Log.WriteEntry("missed P");
if(ttLaborDtlRow.LaborType == "S" && ttLaborDtlRow.LaborQty > 0)
throw new Ice.BLException("Quantity not allowed on Setup activity. Change Current Quantity to zero.");
Ice.Diagnostics.Log.WriteEntry("MD Labor Update stop over reporting exit");
