Hello,
I created a user, added it to the company, and logged into that user’s account (created a new password).
When going into User Account Maintenance and hitting the delete button, I am getting an error. I removed all options, groups, and company from this user.
The error message:
## System Information ##
AppServer Connection: domain
Form Name: User Account Maintenance
Customization Name:
Menu ID: SUSC1010
Software Version: 4.1.200.0
Server Side Exception
A server error occurred. Review the server event logs for details.
## Error Detail ##
##!Correlation ID:##! 04286e7a-7bf7-4c88-9e14-d39e7e613425
##!Description:##! A server error occurred. Review the server event logs for details.
##!Program:##! Epicor.Ice.Server.Wcf.Core.dll
##!Method:##! ProvideFault
##!Line Number:##! 33
##!Column Number:##! 17
##!Server Trace Stack:##! at Epicor.Hosting.Wcf.ErrorHandler.ProvideFault(Exception error, MessageVersion version, Message& fault) in C:\_releases\ICE\ICE4.1.200.16\Source\Server\Hosting\Wcf\Ice.Server.Wcf.Core\Hosting\Wcf\ErrorHandler.cs:line 33
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideFault(Exception e, FaultConverter faultConverter, ErrorHandlerFaultInfo& faultInfo)
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideMessageFaultCore(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage8(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.ProcessError(Exception e)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.Runtime.InputQueue`1.AsyncQueueReader.Set(Item item)
at System.Runtime.InputQueue`1.EnqueueAndDispatch(Item item, Boolean canDispatchOnThisThread)
at System.Runtime.InputQueue`1.EnqueueAndDispatch(T item, Action dequeuedCallback, Boolean canDispatchOnThisThread)
at System.ServiceModel.Channels.SingletonChannelAcceptor`3.Enqueue(QueueItemType item, Action dequeuedCallback, Boolean canDispatchOnThisThread)
at System.ServiceModel.Channels.HttpPipeline.EnqueueMessageAsyncResult.CompleteParseAndEnqueue(IAsyncResult result)
at System.ServiceModel.Channels.HttpPipeline.EnqueueMessageAsyncResult.HandleParseIncomingMessage(IAsyncResult result)
at System.Runtime.AsyncResult.AsyncCompletionWrapperCallback(IAsyncResult result)
at System.ServiceModel.Channels.HttpInput.ParseMessageAsyncResult.OnRead(IAsyncResult result)
at System.Web.Hosting.AsyncResultBase.Complete(Int32 hresult, Boolean synchronous)
at System.Web.Hosting.PipelineRuntime.AsyncCompletionHandler(IntPtr rootedObjectsPointer, Int32 bytesCompleted, Int32 hresult, IntPtr pAsyncCompletionContext)
## Client Stack Trace ##
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.UserFileImpl.Update(UserFileDataSet ds)
at Ice.Adapters.UserFileAdapter.OnDelete()
at Ice.Lib.Framework.EpiBaseAdapter.Delete(DataRow dr)
at Ice.UI.App.UserAccountEntry.Transaction.Delete()
I could try deleting the user in the REST API, but don’t want to corrupt any data on our main DB.
Is there a way I can safely delete this user?
Thanks!
