How to return a DataSet from an Epicor Function?
I want to return a dataset from an Epicor Function (v.10.2.500) which calls an API. Request parameter to the Function is a String and the Response Parameter defined as System.Data.DataSet.
It will always be one row of data, but 20+ fields. I need fields of dataset returned.
I want to call this Function from a Data Directive and doing the following:
part = ud27.PartNum;
InfoMessage.Publish("Search - Part: " + part);
// Call Web Service to get the Part Table.
var result = (Tuple<System.Data.DataSet>)this.InvokeFunction(“PartWebService”, “PartSearch”, Tuple.Create(part));
DataSet dataSet = result?.Item1;
var outputStr = dataSet?.Tables[0]?.Rows[0][0]?.ToString();
InfoMessage.Publish("PartSearch :" + outputStr);
} // end webservice call
You just need to create / populate the data set in the function as you show in your screen shot there should be a dataSet paramter in your function so you can do
DataTable dt = new DataTable();
dt.Columns.Add(....)
dataSet.Tables.Add(dt)
etc...
Yes, I am populating the DataSet inside the Function as follows. I am not sure how to return DataSet to the DataDirective. Am I calling the Function correctly? I know v.10.2.500 was the first release of Functions and a bit buggy.
    DataTable dataTable = new DataTable();
	dataTable.Columns.Add("PartNumber", typeof(string));
	dataTable.Columns.Add("ItemType", typeof(string));
	dataTable.Columns.Add("Description", typeof(string));
	dataTable.Columns.Add("MeasurementUnits", typeof(string));
	dataTable.Columns.Add("BeltWidth", typeof(string));
	dataTable.Columns.Add("BeltLength", typeof(string));
	dataTable.Columns.Add("BeltLengthSubInches", typeof(string));
	dataTable.Columns.Add("MetricWidth", typeof(string));
	dataTable.Columns.Add("MetricLength", typeof(string));
	dataTable.Columns.Add("ImperialWidth", typeof(string));
	dataTable.Columns.Add("ImperialLengthFeet", typeof(string));
	dataTable.Columns.Add("ImperialLengthInches", typeof(string));
	dataTable.Columns.Add("MeasurementReferenceCode", typeof(string));
	dataTable.Columns.Add("Material", typeof(string));
	dataTable.Columns.Add("Finish", typeof(string));
	DataRow row = dataTable.NewRow();
	row["PartNumber"] = partInfo.PartNumber;
	row["ItemType"] = partInfo.ItemType;
	row["Description"] = partInfo.Description;
	row["MeasurementUnits"] = partInfo.FB.measurementUnits;
	row["BeltWidth"] = partInfo.FB.beltWidth;
	row["BeltLength"] = partInfo.FB.beltLength;
	row["BeltLengthSubInches"] = partInfo.FB.beltLengthSubInches;
	row["MetricWidth"] = partInfo.FB.metricWidth;
	row["MetricLength"] = partInfo.FB.metricLength;
	row["ImperialWidth"] = partInfo.FB.imperialWidth;
	row["ImperialLengthFeet"] = partInfo.FB.imperialLengthFeet;
	row["ImperialLengthInches"] = partInfo.FB.imperialLengthInches;
	row["MeasurementReferenceCode"] = partInfo.FB.measurementReferenceCode;
	row["Material"] = partInfo.FB.material;
	row["Finish"] = partInfo.FB.finish;
	dataTable.Rows.Add(row);
	dataSet.Tables.Add(dataTable);
What is the issue? Yeah this is the first release of Functions and I don’t even know if it works in Data Directives at this point but it looks fine.
Are you just getting an error?
I am not getting any errors in either the data directive nor function. But, I am getting no data back either. The API definitely works as I can call this in Visual Studio code. I am not sure if it is bug in this release or just something I am doing wrong calling it. I have called other Functions from data directive but just passing strings, this is the first time trying to return a DataSet.
Did you name your DataTable, and are referencing that name correctly?
I don’t see it.
You forgot to initialize your dataset. Add the line below at the top of your code:
dataSet = new DataSet();
I do, I just did not include in the code snippet. This is the entire code in the Function:
string apiUrl = "http://apiurllink";
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(apiUrl);
request.Method = "GET";
DataSet dataSet = new DataSet();
using (HttpWebResponse response = (HttpWebResponse)request.GetResponse())
    if (response.StatusCode == HttpStatusCode.OK)
        using (Stream stream = response.GetResponseStream())
            using (StreamReader reader = new StreamReader(stream))
                string content = reader.ReadToEnd();
                // Deserialize the JSON response
                dynamic responseData = JsonConvert.DeserializeObject(content);
                // Access the data
                string message = responseData.message;
                dynamic partInfo = responseData.partInfo;
                bool isError = responseData.isError;
                if (!isError)
                    // Write to log here:
                    //Ice.Diagnostics.Log.WriteEntry($"[ {efxName} ] writing to application log...");
Have you tested that function in swagger?
I finally got it working in a Data Directive. (I will share the code when it is cleaned-up).
Now, I want to call the Function in a form customization as well but there is no 10.2.500.x version of Epicor.Lib.RestClient.dll…does anyone have this? I tried using a more current version DLL, but could not get the code compile in the Editor.
Use httpclient or add restsharp.
You can use the EpiRest Library you just have to deploy it with the client.
using EpicorRestAPI;
SetupEpicorRest("APIKey")
var response = EpicorRest.EfxPost("CustomerPortal", "GenerateNewPassword", new { });
GeneratePwdResponse pwdResp = Newtonsoft.Json.JsonConvert.DeserializeObject<DataSet>(response.ResponseBody);
if(!response.IsErrorResponse)
// do something with response.Properties
public bool SetupEpicorRest(string apiKey)
        try
            string appUri =AppSettingsHandler.GetValue(AppSettingsSections.Application, "AppServerURL", null);
            var uri = new Uri(appUri);
            EpicorRestAPI.EpicorRest.AppPoolHost=uri.Host;
            EpicorRest.AppPoolInstance = uri.LocalPath.Replace("/","");
            EpicorRest.APIKey = apiKey;
            var session = oTrans.Session as Ice.Core.Session;
			EpicorRest.Company = session.CompanyID;
			Assembly sm = Assembly.LoadFrom("Epicor.ServiceModel.dll");  // Kinetic Uplift
			object authClass = sm.CreateInstance("Epicor.ServiceModel.Wcf.Security.AuthenticationWcf");  // Kinetic Uplift
			Type smType = authClass.GetType();  // Kinetic Uplift
			BindingFlags bf = BindingFlags.Instance|BindingFlags.NonPublic|BindingFlags.Public;  // Kinetic Uplift
			MethodInfo mi = smType.GetMethod("IsWindows", bf);  // Kinetic Uplift
			object[] invParams = new object[1]{AppSettingsHandler.AuthenticationMode};  // Kinetic Uplift
			bool isWindows = (bool)mi.Invoke(authClass,invParams);  // Kinetic Uplift
            var accessTokenFunc = typeof(Ice.Core.Session).GetProperty("GetAccessTokenFunc", BindingFlags.Instance|BindingFlags.NonPublic|BindingFlags.Public).GetValue(session) as Func<bool,string>;
            if(accessTokenFunc !=null)
                EpicorRest.BearerToken = accessTokenFunc(false);
			else if(isWindows) // Kinetic Uplift
                EpicorRest.UserName = Environment.UserName;
                EpicorRest.Password = "";
            else
                object clientCreds = typeof(Ice.Core.Session).GetProperty("ClientCredentials", BindingFlags.Instance|BindingFlags.NonPublic|BindingFlags.Public).GetValue(session);
                if(clientCreds!=null)
                    object clientCredsUname = clientCreds.GetType().GetProperty("UserName").GetValue(clientCreds);
                    EpicorRest.UserName =clientCredsUname.GetType().GetProperty("UserName").GetValue(clientCredsUname) as String;
                    EpicorRest.Password =clientCredsUname.GetType().GetProperty("Password").GetValue(clientCredsUname) as String;
            return true;
        catch(Exception ex)
            return false;
