How to retrieve value from table and display in text field on screen using script editor
I would like to retrieve a value from the CheckHed table and display it in a text field on the screen. I would like the lookup to happen when a NEW record is loaded so when the user finishes adding the additional information the lookup value will be saved back to the database when the record is saved. I am writing the customization in the screen script editor and would like to know the proper steps to retrieve the value and display it in the text field. We are on Epicor 10.1.500.8 and all the examples I am finding seem to be on older systems or still using VB.
I am not opposed to a different approach if there is a better method so any assistance with this is greatly appreciated.
Jeffrey,
Here’s a write-up I did on a customization of the Part form. One of the
components looks up a part description and displays it in a text field, but
does not store it.
See if it helps.
Joe
Notes:
Joe’s changes marked with //JDT in red.
These changes revolved around the entry and validation of a “Service Part”
part number and the lookup/display of a part description on entry of the
field and when reading in the part.
Also included is read-only security applied to controls of specified group
boxes for specified security groups.
// Custom code for PartForm
// Created: 2/6/2016 5:19:57 PM
extern alias Erp_Contracts_BO_Part;
extern alias Erp_Contracts_BO_PartPlantSearch;
extern alias Erp_Contracts_BO_PO;
extern alias Erp_Contracts_BO_PartOnHandWhse;
extern alias Erp_Contracts_BO_Vendor;
extern alias Erp_Contracts_BO_VendorPPSearch;
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using System.Drawing;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
            // ** Wizard Insert Location - Do Not Remove 'Begin/End
Wizard Added Module Level Variables’ Comments! **
            private EpiDataView edvPart;
            private EpiBaseAdapter oTrans_adapter;
                            // ** Wizard Insert Location - Do not
delete ‘Begin/End Wizard Added Variable Initialization’ lines **
                            // Begin Wizard Added Variable
Initialization
                            this.Part_Column.ColumnChanging += new
DataColumnChangeEventHandler(this.Part_BeforeFieldChange);
                            this.edvPart =
((EpiDataView)(this.oTrans.EpiDataViews[“Part”]));
                            this.edvPart.EpiViewNotification += new
EpiViewNotification(this.edvPart_EpiViewNotification);
                            this.oTrans_adapter =
((EpiBaseAdapter)(this.csm.TransAdaptersHT[“oTrans_adapter”]));
                            this.oTrans_adapter.AfterAdapterMethod +=
new AfterAdapterMethod(this.oTrans_adapter_AfterAdapterMethod);
this.chkMesQaVerification.AfterCheckStateChanged += new
Infragistics.Win.CheckEditor.AfterCheckStateChangedHandler(this.chkMesQaVerification_AfterCheckStateChanged);
                            this.cmbMesQaType.Leave += new
System.EventHandler(this.cmbMesQaType_Leave);
delete ‘Begin/End Wizard Added Object Disposal’ lines **
this.chkMesQaVerification.AfterCheckStateChanged -= new
                            this.cmbMesQaType.Leave -= new
                            this.Part_Column.ColumnChanging -= new
                            this.edvPart.EpiViewNotification -= new
                            this.edvPart = null;
                            this.oTrans_adapter.AfterAdapterMethod -=
                            this.oTrans_adapter = null;
                            // Begin Custom Code Disposal
                            // End Custom Code Disposal
            private void PartForm_Load(object sender, EventArgs args)
//JDT – This section looks up the user ID, reads the security groups and
security manager, and applies “read only” to controls belonging to two
group boxes if not security manager or in the right security group
                            Ice.Core.Session session =
(Ice.Core.Session)PartForm.Session;
                            bool recSelected = false;
                            string secGroup = "";
                            bool secManager = false;
                            string whereClause = "DcdUserID = '" +
session.UserID + “’”;
                            DataSet dsUser =
Ice.UI.FormFunctions.SearchFunctions.listLookup(oTrans, “UserFileAdapter”,
out recSelected, false, whereClause);
                            if (recSelected)
                                                            secGroup =
Convert.ToString(dsUser.Tables[0].Rows[0][“GroupList”]);
                                                            secManager
= Convert.ToBoolean(dsUser.Tables[0].Rows[0][“SecurityMgr”]);
                            if (!("~" + secGroup + "~").Contains("~" +
“ENGA01” + “~”) && !secManager)
                                                            foreach
(Control sPlate in grpSerialPlate.Controls)
sPlate.Enabled = false;
                                                            foreach
(Control sPlateImage in grpSPImages.Controls)
sPlateImage.Enabled = false;
            private void
chkMesQaVerification_AfterCheckStateChanged(object sender, System.EventArgs
args)
                            if(this.chkMesQaVerification.Checked)
                                            this.txtMesQaLabel.Enabled
= true;
                                            this.cmbMesQaType.Enabled =
true;
this.txtMesQaOtherQaCode.Enabled = true;
this.txtMesQaOtherQaCode2.Enabled = true;
this.chkMesQaPartialMatch.Enabled = true;
setTxtMesQaOtherQaCodeEnable();
                            else
= false;
false;
this.txtMesQaOtherQaCode.Enabled = false;
this.txtMesQaOtherQaCode2.Enabled = false;
this.chkMesQaPartialMatch.Enabled = false;
            private void cmbMesQaType_Leave(object sender,
System.EventArgs args)
            private void setTxtMesQaOtherQaCodeEnable()
                            if (cmbMesQaType.Text == "Other")
                            else
            private void Part_BeforeFieldChange(object sender,
DataColumnChangeEventArgs args)
                            // args.Row["FieldName"]
                            // args.Column, args.ProposedValue, args.Row
                            // Add Event Handler Code
                            switch (args.Column.ColumnName)
//JDT – This section displays a part description for a secondary part
number upon entry. Stores the description in a text box with no binding.
                                            case "ServicePartUsePart_c":
EpiDataView edv = ((EpiDataView)(oTrans.EpiDataViews[“Part”]));
string whereClause = “PartNum = '” + txtServicePartUsePart.Text + “’”;
DataSet dsPart = Ice.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
“PartAdapter”, out recSelected, false, whereClause);
if (recSelected)
txtServicePartUsePartDesc.Text =
Convert.ToString(dsPart.Tables[0].Rows[0][“PartDescription”]);
edv.Notify( new EpiNotifyArgs(oTrans, edv.Row, edv.Column) );
                                                            else if
(txtServicePartUsePart.Text == “”)
txtServicePartUsePartDesc.Text = “”;
else
MessageBox.Show("’" + txtServicePartUsePart.Text + “’” + " is not a valid
part number.");
txtServicePartUsePart.Focus();
                                                            break;
            private void edvPart_EpiViewNotification(EpiDataView view,
EpiNotifyArgs args)
                            // view.dataView[args.Row]["FieldName"]
                            // args.Row, args.Column, args.Sender,
args.NotifyType
                            // NotifyType.Initialize,
NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView,
NotifyType.InitAndResetTreeNodes
                            if ((args.NotifyType ==
EpiTransaction.NotifyType.Initialize) && args.Row > -1)
number upon part load
                                            if
(String.IsNullOrEmpty(txtServicePartUsePart.Text))
if(String.IsNullOrEmpty(txtServicePartUsePartDesc.Text) &&
!String.IsNullOrEmpty(txtServicePartUsePart.Text))
                                                            EpiDataView
                                                            bool
                                                            string
                                                            DataSet
                                                            if
(recSelected)
                                                            else
EpiTransaction.NotifyType.AddRow))
                                            if ((args.Row > -1))
            private void oTrans_adapter_AfterAdapterMethod(object
sender, AfterAdapterMethodArgs args)
                            // ** args.MethodName **
                            // ** Add Event Handler Code **
                            // ** Use MessageBox to find adapter method
name
                            // EpiMessageBox.Show(args.MethodName)
                            switch (args.MethodName)
//JDT – This section clears the secondary part description upon clearing
form
                                            case "ClearData":
                                                            break;
Joe, Sorry for the late response on this as I have been away from my computer for a bit. Thank you for the information, I am working through it now.
Once again sorry for the late reply. This information gave what I needed to resolve the issue so I am marking this as the solution.
