How to load initial on hand quantities - Go live Kinetic 2022.1
Anyone have any advice on how to load initial on hand inventory quantities?
We have the part and the part cost set up, would you just do a quantity adjustment DMT?
-Utah
Yes, with DMT.
Quantity adjustment of course, yeah?
What I am hoping to avoid is any weirdness when you do recalc balances or refresh part bin or refresh part quantities because we mess up the initial inventory load.
thanks Mark.
You might also want to consider turning off the Inventory interface in Company Configuration for the Qty load depending on how you are handling the GL import.
If the Inventory Interface is true
  1. Cost Adjustment with Reason code
  2. Quantity Adjustment with Reason code
    After doing Step 1 & 2 this will Debit Inventory & Credit Reason Code, we try to choose same reason code.
    On Trial Balance upload we debit the Reason Code account.
Mohit, thank you. I believe this is how we intend to do it.
