All of our tooling at our company we either manufacture or purchase. We have problems running MRP because of the fact that it can’t figure out that the same tooling part can be used over and over. Since we have over 1500 different tools, we have hundreds and hundreds of job and PO suggestions appear when we run MRP. I am wondering if anyone else has ran into this and how do they handle tooling requirements in Vantage. We can’t run a proper schedule because of how much the tooling muddies it all up. Any suggestions?
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone: +1 931 432 8408
Fax: +1 931 432 1889
Mail: mabell@...
Website:
http://www.flexial.com
http://www.boagroup.com
We have our tools listed as a resources. Our jobs have an operation that uses the tool of choice. We have a corresponding Part number, which we link to the resource, allowing for maintenance or shipping if it needs to be sent out for repair. A BPM watches for shipments and will make the tool inactive if the quantity drops below zero.
Brenda
Sent: Thursday, November 05, 2015 3:39 PM
Subject: [Vantage] How to handle tooling when it comes to MRP - Vantage 8.03
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:
mabell@...
Website: http://www.flexial.com
We made a tool revision and put all of the tools there. We can reference it by part number, but it has no impact on the mrp process.
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:
mabell@...
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
How do you have these configured in part entry? Currently, while it isn't perfect by any means, it seems manageable for us. We manufacture most of our tooling, most which we own, some are customer owned. They go in the MOM simply as a fixed qty of one under the parent part number that needs the tooling. In part entry, we remove the backflush and MRP options as well as generate suggestions. For us tooling is inventoried at zero dollars unless it is customer owned.
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
www.dsmfg.com<http://www.dsmfg.com>
Sent: Thursday, November 5, 2015 2:39 PM
All of our tooling at our company we either manufacture or purchase. We have problems running MRP because of the fact that it can't figure out that the same tooling part can be used over and over. Since we have over 1500 different tools, we have hundreds and hundreds of job and PO suggestions appear when we run MRP. I am wondering if anyone else has ran into this and how do they handle tooling requirements in Vantage. We can't run a proper schedule because of how much the tooling muddies it all up. Any suggestions?
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail: mabell@...
Website: http://www.flexial.com<http://www.flexial.com/>
http://www.boagroup.com<http://www.boagroup.com/>
Rob, thanks so much for the suggestion. Our tools are setup on the MOM similarly as yours with the exception that we DO have process MRP and DO have Generate PO suggestions turned on which is why we end up with hundreds upon hundreds of suggestions to manufacture/purchase tooling. Not sure about the fixed qty but sounds like something we would want to do.
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail: mabell@...
Website:
Sent: Friday, November 06, 2015 6:57 AM
Subject: [Vantage] RE: How to handle tooling when it comes to MRP - Vantage 8.03
Mike,
Rob Bucek
D&S Manufacturing
rbucek@...
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail: mabell@...
Rob Bucek
D&S Manufacturing
rbucek@...
Sent: Friday, November 6, 2015 8:49 AM
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail: mabell@...
Mike,
Rob Bucek
D&S Manufacturing
rbucek@...<mailto:rbucek@...>
www.dsmfg.com<http://www.dsmfg.com<http://www.dsmfg.com%3chttp:/www.dsmfg.com>>
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail: mabell@...<mailto:mabell@...>
Website: http://www.flexial.com<http://www.flexial.com/<http://www.flexial.com%3chttp:/www.flexial.com/>>
http://www.boagroup.com<http://www.boagroup.com/<http://www.boagroup.com%3chttp:/www.boagroup.com/>>
