I’ve been trying to set up the Epicor Expense app and it seems to work great. However, I need to explore possibilities for example, setting default values. I see that there is a MobileEmpExpense table so in theory I could set a BPM on that and set the value on the GetNew (there are 2 fonctions but neither work) but I can’t make it work. I would like to be able to see the logs to see what exactly is called.
Is that possible to do that with the ‘tracing options form’ ?
(It’s just an example, I know that I can use Quick Code to easily set default values)
Thanks !
