How to find what Calc is being used in Dashboard Calculated Field?
Within “Dashboard Grid Properties” for a particular Dashboard, I have a column named “Calculated_QtyAdjHrs”. How can I find what values are used for that Calculation?
You’ll either need to open up the dashboard and find the baq it is built from, and then open the baq in query designer, or you can run a trace with write full dataset and you can see it in there.
