Success! Thank you.
It turns out I was missing Steps 20 through 25.
I am now able to deploy and test my customization (and I found out
the button actually doesn't work yet.)
I will figure out what is wrong with my button then I can follow
Steps 25-26 for the rest of the users.
Thanks a lot!
Lynn
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
Thanks a lot!
Lynn
wrote:
>instead of
> This works. Pay attention to Step #25.
> AnswerBook #: 5213MPS Product: Vantage
> Added:
> Changed: 04/07/2008 Module: MES
> 07/06/2005 Version: 8.00.800
> Details:
> Summary:
> CUST How do you customize the main MES Menu and set to use it
> defaultlist
> PROBLEM:
> How do you customize the main MES Menu and set to use it instead of
> default?
> SOLUTION:
> 1. Right-click on the shortcut for Vantage 8.0 MES.
> 2. Copy and paste the copy to the desktop.
> 3. Rename the copy to something like MES Developer.
> 4. Right-Click and choose Properties.
> 5. In the Target area, locate where it shows -MES and change it to
> -MESC.
> 6. Click OK to save the changes.
> 7. Login to MES Developer.
> 8. Make your customizations and choose Save as
> 9. Give your customization a name (i.e CustomMES)
> 10. Save and close MES
> 11. Log into a your a regular 8.0 session
> 12. Go to System Management >> Utilites >> Sub Process Maintenance
> 13. Create a new menu ID and give it a name e.g UDMES1
> 14. Choose the security you want to apply to this option
> 15. Enter a parent process like PROCESS or MAINMENU
> 16. Enter a unique number for the sequence like 10, 15, 20, etc.
> 17. Under the Program section browse to or type in
> Epicor.Mfg.Menu.Mes.dll
> 18. Choose the Customization name you saved in steps 4/5 from the
> boxfor
> 19. Save and close Sub Process Maintenance
> 20. Create a Process Calling using System Management >> Utilities >>
> Process Calling Maintenance
> 21. Choose File >> New
> 22. Process Called Reference = Epicor.Mfg.Menu.MES
> 23. Menu ID = UDMES1 (Menu ID create in step 13)
> 24. Save and close Process Calling Maintenance
> 25. Add the process ID you just created in step # 13 as the value
> the MESCustomMenuID node in thethe
> xxx.mfgsys file being referenced by your MES icon
> <MESCustomMenuID value="UDMES1" /> This should be listed under the
> <appSettings>
> </appsettings> section. If the icon does not reference mfgsys use
> default.mfgsys foundcustomization.
> the ...epicor/client/config directory.
> 26. Log into 8.0 MES again and you should now see your
>file
> Note 1: When first installed you will need to change the xxx.mfgsys
> used by each MES user. You'll findpilot.mfgsys.
> this file in the config directory of the epicor client folder e.g.
> c:\epicor\mfgsys803\client\config
> Note 2: In a standard implementation of Vantage the name of the file
> being changed is default.mfgsys.
> HOWEVER, this can change based on your installation of Vantage. For
> example if you are running against a
> test or pilot database the file maybe named test.mfgsys or
> You may want to check the portdirectory
> number of the appserver that MES is using agains the AppServerURL
> value="AppServerDC://LAPIZ:8301"
> statement in the default.mfgsys.
> Note 3: Be sure to change the one in the Vantage client config
> stored on the server. This wayBehalf
> when you install a new release of Vantage and the client folders are
> updated the modified xxx.mfgsys is
> downloaded.
> -----Original Message-----
> Of Lynnto
> Sent: Tuesday, October 21, 2008 12:12 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] How to Deploy a MES Customization
> I created a customization to program a blank button on the MES Menu
> following AnswerBook 6539MPS.
> Now that the customization is saved, the Epicor instructions refer
> AnswerBook 4306MPS to deploy the MES Customization. However thisCustomization
> AnswerBook is not published on the website.
> I found some instruction in the Vantage Help menu for MES
> and followed those instructions for Sub Process Maintenance.programmed
> I opened, then closed, then re-opened Vantage and MES.
> It didn't work. No matter what I do, I cannot see the newly
> button on the MES menu.must
> Can anyone tell me how to deploy my MES menu customization?
> Does anyone have a copy of Answerbook 4306MPS?
> I am on Vantage 8.03.404.
> Thanks.
> Lynn
> have already linked your email address to a yahoo id to enableaccess. )
> (1) To access the Files Section of our Yahoo!Group for ReportBuilder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
