How to create a "previous entry" field
Hello all, I’m looking to store an old value of a textbox field into a UDfield before it’s changed so that when the textbox value changes to a new value, I can have a previous value and current value to play with. Can anyone lead me in the right direction? I am able to comprehend C# code and the different form event wizards. Thank you in advance!
You want a before field change event on the relevant dataview/field. Use the event wizard.
Note that you’ll need to have your variable already declared. In my example below, it would be:
string myValue;
	private void Resource_BeforeFieldChange(object sender, DataColumnChangeEventArgs args)
		// args.Row["FieldName"]
		// args.Column, args.ProposedValue, args.Row
		// Add Event Handler Code
		switch (args.Column.ColumnName)
			case "AssetNum":
			myValue =  args.Row["AssetNum"].ToString();
				break;
Also ensure you know what type of data to expect (string,int, etc)
Thank you for the help!
