How to copy data from E10 to Kinetic in a easy way?
Hello,
I have Kinetic environment all setup. Now the issue is how do I copy data from E10 to Kinetic without upgrading the database? My goal is to move to Kinetic within a day. Is there an easy way?
Yixin
What data are you wanting to move?
Hi Jose,
I would like to copy all the data from the E10 database.
No possible without a upgrade you need to do an upgrade. Or you will have a lot of corrupted, bad data.
Thanks! Jose.
Once you have an upgraded version of your system, depending on what modules there is the DMT diff functionality. Still will require work and investigation and testing.
Thank you Simon, I will take a look!
