I want to call a quick search in customization (E10), while at the same time filter the result set/pass in value as default parameter which allow user to be selected in the search dialog.
I used the following code, under debug mode, i found that the “CriteriaValue” can be updated in the QuickSearchDataSet.
However, none of the function/method (#1 or #2), which showing the quick search panel, can accept the parameter (default value at the search panel) or filter the result set.
