I'm glad I could help!
Thanks for sharing your final code, I can see myself coping this example
for a upcoming task.
Of zanniebelle
Sent: Friday, November 19, 2010 8:23 AM
Subject: [Vantage] Re: How To Call a BAQ from Customization Code?
Hi Joe,
I used your advice and got it to work. I added the criteria rows to the
BAQ setting each field to ' '. Then I changed the value for each field
in my method before calling Execute(see code below).
Thanks for you help!
Ray
private static void GetSignHistory(string as_custNum, string
as_shipToNum, string as_partnum, string as_seq)
DynamicQuery dqa = new DynamicQuery(_session.ConnectionPool);
QueryDesignDataSet qdds = dqa.GetByID(SIGN_HISTORY_BAQ);
foreach (DataRow lo_row in qdds.QueryWhereItem.Rows)
switch (lo_row["FieldName"].ToString())
case "Key1":
lo_row["RValue"] = as_custNum;
break;
case "Key2":
lo_row["RValue"] = as_shipToNum;
break;
case "Key3":
lo_row["RValue"] = as_partnum;
break;
case "Key4":
lo_row["RValue"] = as_seq;
break;
DataSet ds = dqa.Execute(qdds);
epiUltraGridSignHistory.DataSource = ds;
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Joe
Rojas <jrojas@...> wrote:
Behalf
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Of zanniebelle
Hi Joe,
Ray
case "Key1":
break;
case "Key2":
break;
case "Key3":
break;
case "Key4":
break;
>new
> I think I remember having this issue but in my case I only had one
> criteria.
> The issue is that you can only have one new row at a time.
> In essence, you'd have to run Update(qdds) after each AddWhereItem.
> What I'm not sure about is if this will actually modify the BAQ on the
> server.
> Another approach would be to try and modify the RowMod field for the
> criteria after the AddWhereItem runs.3)
> Something like: qds.Tables["QueryWhereItem"].Rows[0]["RowMod"] = ""
> You'd have to change Rows[0] to the last number plus 1 (e.g. 0, 1, 2,
>dataset,
> Lastly, you could define the criteria directly in the BAQ for Key 1 to
> Key 4 and set each on equal "", then after you retrieve the BAQ
> modify each only using a similar syntax as above.[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Just spit balling here.
Behalf
> Of zanniebelledqa.AddWhereItem(qdds,ls_queryId,ls_table,ls_field,ls_condition,lb_isCon
> Sent: Thursday, November 18, 2010 4:08 PM
> Hi Joe,
> I have tried to get this to work and I am able to call the BAQ, but it
> seems that I can only add one WhereItem. When I add more than one only
> the last one added affects the results. Do you see anything I'm doing
> wrong here?
> string ls_queryId = SIGN_HISTORY_BAQ;
> string ls_table = "UD09";
> string ls_field = "Key1";
> string ls_condition = "=";
> string ls_empty = String.Empty;
> bool lb_isConst = true;
> st,as_custNum,ls_empty,ls_empty,ls_empty,ls_empty,"And",false);dqa.AddWhereItem(qdds,ls_queryId,ls_table,ls_field,ls_condition,lb_isCon
> ls_field = "Key2";
> st,as_shipToNum,ls_empty,ls_empty,ls_empty,ls_empty,"And",false);dqa.AddWhereItem(qdds,ls_queryId,ls_table,ls_field,ls_condition,lb_isCon
> ls_field = "Key3";
> st,as_partnum,ls_empty,ls_empty,ls_empty,ls_empty,"And",false);dqa.AddWhereItem(qdds,ls_queryId,ls_table,ls_field,ls_condition,lb_isCon
> ls_field = "Key4";
> st,as_seq,ls_empty,ls_empty,ls_empty,ls_empty,"",false);records
> The results all have the same sequence (as_seq) number, but different
> part numbers and shipto numbers.
> If I comment out the last AddWhereItem the results only contains
> where there is a partnumber match (as_partNum)<mailto:vantage%40yahoogroups.com> , Joe
> Any help you can provide is appreciated!
> Thanks,
> Ray
> Rojas <jrojas@> wrote:screen.
> > Sorry, I was in a rush but I wanted to give you an answer.
> > I decided to work with the BO instead of the adapter. If you're
> familiar
> > with working in the BAQ designer, some of these parameters should be
> > familiar.
> > The example I gave is if you want to add criteria to your BAQ at
> > runtime. However, if you just want to call a BAQ without adding
> criteria
> > at runtime, then you can just call the ExexcuteByID method instead.
> > I'll comment in the code below to try and explain.
> > "<FormName>" is the name of the form you are calling this code from.
> It
> > can be found at the top of the tree view in the customization
> >DynamicQuery(episession.ConnectionPool)
> > This creates a session object that is needed to create the
> DynamicQuery
> > BO
> > Dim episession As Session = CType(<FormName>, Session)
> > Create the DynamicQuery BO
> > Dim dqa As DynamicQuery = New
> >dqa.GetByID("MATS-ProjectInfluencers")
> > Pass the GetByID method the name of the BAQ that you want to call
> > This will return a dataset that contains the details of the BAQ
> > Dim ds As QueryDesignDataSet =
> > Only use these variables if you need to add criteria at runtime
> > The name of your BAQ
> > Dim pcQueryID as String = "MATS-ProjectInfluencers"
> > The name of the table in your BAQ that you want to add a criteria
> > against
> > Dim pcTable as String = "UD04"
> > The field in the table above that will be used in your criteria
> > Dim pcField as String = "Key1"
> > The comparison operator for your criteria
> > Dim pcCondition as String = "="
> > Set to true if comparing to a constant value, false if comparing to
> > another field
> > Dim pbIsConst as Boolean = true
> > If above is true, the constant value
> > Dim pcValue as String = "2010-0"
> > If pbIsConst is false then this is the comparison table
> > Dim pcToTable as String = String.Empty
> > If pbIsConst is false then this is the comparison field
> > Dim pcToField as String = String.Empty
> > Do you want to set a left parentheses
> > Dim pcLeftParentheses as String = String.Empty
> > Do you want to set a right parentheses
> > Dim pcRightParentheses as String = String.Empty
> > If assigned more than one criteria, set the And or Or between the
> > criteria
> > Dim pcAndOr as String = String.Empty
> > Is this a negation criteria, same as checking the Not checkox
> > Dim pbNeg as Boolean = false
> > Calls AddWhereItem to add the criteria created above to BAQ dataset
> > dqa.AddWhereItem(ds, pcQueryID, pcTable, pcField, pcCondition,
> > pbIsConst, pcValue, pcToTable, pcToField, pcLeftParentheses,
> > pcRightParentheses, pcAndOr, pbNeg)
> > Execute the BAQ and store the results in a dataset
> > Dim DQResults As DataSet = dqa.Execute(ds)
> > Assign the dataset to an EpiUltraGrid
> > ugInfluencers.DataSource = DQResults
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On
> Behalf<mailto:vantage%40yahoogroups.com>
> > Of zanniebelle
> > Sent: Thursday, November 18, 2010 1:15 PM
> > Subject: [Vantage] Re: How To Call a BAQ from Customization Code?<mailto:vantage%40yahoogroups.com>
> > Thanks Joe for the reply.
> > Can you provide a little more detail on the parameters and their
> > purpose?
> > For example is "MATS-ProjectInfluencers" the BAQ your calling?
> > Ray
> > Any additional help is appreciated.
> <mailto:vantage%40yahoogroups.com> , Joe<mailto:vantage%40yahoogroups.com>
> > > Here is an example that I posted a few months back
> <mailto:vantage%40yahoogroups.com> ] On<mailto:vantage%40yahoogroups.com>
> > Behalf
> > > Of zanniebelle
> > > Sent: Thursday, November 18, 2010 12:57 PM
> <mailto:vantage%40yahoogroups.com>code
> > > Subject: [Vantage] How To Call a BAQ from Customization Code?
> > > Hi All,
> > > Does anyone have an example of calling a BAQ from customization
> > > that will fill a DataSet?Joe Rojas | Director of Information Technology | Mats Inc
> > > Thanks,
> > > Ray
