Hi team,
I have Created SSRS report from report designer and its working fine. i have added this report to form but if i click on that button then its not pick value from form key like ponum, OrderNum…
if i manually add value then its showing preview. set-item method showing error. Please guide.
Hi Dinesh, welcome!
Same issue with Report created by Report Designer. Please help
@DineshYadav001 We are going to need a little more information to help diagnose. Can you provide the code you are using to run the report via code? The more screenshots the better. Also need a screenshot of that error you are getting
private void epiBtnPrint_Click(object sender, System.EventArgs args)
// ** Place Event Handling Code Here ** TestBAQ
EpiTextBox txtPart =(EpiTextBox)csm.GetNativeControlReference("8e25166f-6185-4497-b3d6-1798e4e9c4a0");
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.ValueIn = "TestBAQ";
UIReflector BAQForm = ProcessCaller.LaunchCallbackForm(oTrans, "TestBAQ", lfo);
EpiDataView ParamView = (EpiDataView)BAQForm.UITrans.EpiDataViews["ReportParam"];
ParamView.dataView[ParamView.Row].BeginEdit();
EpiDataView INSView = (EpiDataView)(oTrans.EpiDataViews["InspDataParam"]);
ParamView.dataView[ParamView.Row]["numQuoteNum_1"] = txtPart.Text.ToString();
ParamView.dataView[ParamView.Row].EndEdit();
BAQForm.UITrans.NotifyAll();
You are going to need to share your parameter configuration for the report.
Yes I want that parameter auto fetch from form.
Try the below code at your BaqReport Form
private void BAQReportForm_Load(object sender, EventArgs args)
if(BAQReportForm.LaunchFormOptions != null)
string val = BAQReportForm.LaunchFormOptions.ValueIn.ToString();
string[] items = val.Split('~');
string QuoteNum = items[0];
string CarcassBrand = items[1];
EpiDataView view = ((EpiDataView)(this.oTrans.EpiDataViews["ReportParam"]));
view.dataView[view.Row].BeginEdit();
view.dataView[view.Row]["field1"]= QuoteNum;
view.dataView[view.Row].EndEdit();
view.dataView[view.Row]["field2"]= CarcassBrand;
oTrans.Update();
//txtfield1.Text = QuoteNum;
//txtfield2.Text = CarcassBrand;
else
I believe Chris means how you have configured your parameter on the BAQ Report Designer screen.
