How this has been build
Hi,
We have modification which are failing after update.
Modification designed to open custom popup window with current opcodes for commenting when someone approves revision in part entry.
On part entry screen I can not see anything related to this only few external alias, but when I press approve, it shows that there is a modification under PartEntry.CheckInForm when I chose it, customized popup window apears but I can not get in to see what is the custom code inside.
Can anyone point me how this has been done and how to get in to edit code?
Oh my :smiley:
such an obvious fail :smiley:
There is also an app called Customization Maintenance. You can view the code from there as well…
