I’ve got to be missing something very obvious, but I cannot find the option to use an existing Quick Search in the Kinetic UI. We’re upgrading, and successfully imported an existing Quick Search that I can find and use through the classic UI in 2022.2.11. In the Kinetic UI, I can search in multiple places through either the search magnifying glass button, or right-click, but nothing is offering me access to the Quick Search, I only see options for Basic, Data Tags, and BAQ.
Hi
You need to:
- Open the form that you want to add the quick search to in Classic mode
- Right click and open Quick Search Entry - you will then get a Kinetic Version of Quick Search Entry
- Setup the search as you would in Classic mode
- When you open the search form in the Kinetic form you will be able to select Quick Search as the search type from the drop-down
Hi Sue! I had to deviate a bit from your instructions, but they did the trick. Thanks for the help!
Documenting lessons learned below:
Just a guess, but it seems like you don’t see the ‘Quick Search’ options in the Kinetic UI until a valid one exists for that form. Even thought I had one imported from v9, there was an error in the required & read-only ‘Context Key (Like)’ field that I was only able to resolve by recreating it.
In my case, I did the fix in the Quick Search Classic UI; I do not have the option for Quick Search Kinetic UI. Fortunately, the UIs seems to function the same for Quick Search.
