Hey everyone,
I’ve created a customization the AR Invoice Entry form with a button that will launch a custom BAQ report form and pass values to it.
I’ve also created a customization on the custom BAQ report form to take those values and populate the report parameters with them.
This is working great if I hard code the data in the script, but I cannot figure out how to make it actually use the data directly from the AR Invoice Group.
I was able to piece together the below script using other topics on here. This works and passes the text “GroupID” to the report form.
How do I make it pass the actual GroupID that the user currently has open?
I’ve tried using InvcGrp.GroupID but the code doesn’t compile when I try that.
private void epiButtonC1_Click(object sender, System.EventArgs args)
LaunchFormOptions lfo = new LaunchFormOptions();
lfo.IsModal = false;
lfo.ValueIn = ("GroupID" + "~" + "false" + "~" + "");
ProcessCaller.LaunchForm(oTrans, "ARINVCE", lfo);
