I am trying to return rows the contain PartTran_Company, PartTran_PartNum, PartTran_TranType, PartTran_TranDate but I need to filter it to only the latest PartTran_TranDate for each PartNum.
I was told a query that would filter only the newest date and it worked until I added the TranType field, then it returned the latest dated row for each different TranType.
How do I get the subquery to pass back the field information of TranType and TranDate without it messing up.
Hope this makes sense, any help is greatly appreciated.
I created a subquery, with its own filters.
Then on main query click the SubQueries table icon (see mouse in screenshot) and select the subquery.
Make the logical links
What I am trying to add it to makes it more complicated, I think.
I created a subquery that contains the fields I want to show.
I created a subquery to show only the newest dated rows for each PartNum.
I added both queries to my main query and connected together like picture below.
I joined the PartTranFields (the one with all relevant fields to show) to Part using Comapny and Partnum.
I joined the CalcDate(query that shows only newest dated rows for each partNum) using Company, PartNum, and TranDate.
Below is the one that added the TranType field and made it have more records than the version without it.
select distinct
[Part1].[Company] as [Part1_Company],
[PartTranFields1].[PartTranFields_TranDate] as [PartTranFields_TranDate],
[Part1].[PartNum] as [Part1_PartNum],
[RunningTotal].[Calculated_RunningTotal] as [Calculated_RunningTotal],
[PartTranFields1].[PartTranFields_TranType] as [PartTranFields_TranType],
[Part1].[PartDescription] as [Part1_PartDescription],
[Part1].[TypeCode] as [Part1_TypeCode],
(PartCost.StdLaborCost + PartCost.StdBurdenCost + PartCost.StdMaterialCost + PartCost.StdSubContCost + PartCost.StdMtlBurCost) as [Calculated_TotalCost]
from Erp.Part as Part1
inner join Erp.PartCost as PartCost on
Part1.Company = PartCost.Company
And
Part1.PartNum = PartCost.PartNum
inner join (select
[PartBin].[Company] as [PartBin_Company],
[PartBin].[PartNum] as [PartBin_PartNum],
(sum( PartBin.OnhandQty )) as [Calculated_RunningTotal]
from Erp.PartBin as PartBin
group by [PartBin].[Company],
[PartBin].[PartNum]) as RunningTotal on
Part1.Company = RunningTotal.PartBin_Company
And
Part1.PartNum = RunningTotal.PartBin_PartNum
inner join (select
[PartTranFields].[Company] as [PartTranFields_Company],
[PartTranFields].[PartNum] as [PartTranFields_PartNum],
[PartTranFields].[TranType] as [PartTranFields_TranType],
[PartTranFields].[TranDate] as [PartTranFields_TranDate]
from Erp.PartTran as PartTranFields
inner join (select
[PartTran].[Company] as [PartTran_Company],
[PartTran].[PartNum] as [PartTran_PartNum],
(max( PartTran.TranDate )) as [Calculated_Date]
group by [PartTran].[Company],
[PartTran].[PartNum]) as CalcDate on
PartTranFields.Company = CalcDate.PartTran_Company
And
PartTranFields.PartNum = CalcDate.PartTran_PartNum
And
PartTranFields.TranDate = CalcDate.Calculated_Date) as PartTranFields1 on
Part1.Company = PartTranFields1.PartTranFields_Company
And
Part1.PartNum = PartTranFields1.PartTranFields_PartNum
where (Part1.InActive = 0 and Part1.QtyBearing = 1)
The version I feel may be more accurate but doesn’t contain all the needed fields (returned 3502 rows) is:
select
[CalcDate1].[Calculated_Date] as [Calculated_Date],
And
inner join (select
And
inner join (select
[PartTran].[PartNum]) as CalcDate1 on
Part1.Company = CalcDate1.PartTran_Company
And
Part1.PartNum = CalcDate1.PartTran_PartNum
Just eyballing a quick comparison, the one using distinct has duplicate part numbers in it. I have found a couple in the first 10 rows or so. Assuming it is how I got 260 more rows, so distinct didn’t help.
Any other thoughts? Do you want me to export the 3802 record one so you can look?
select [Part1].[Company] as [Part1_Company], [Part1].[PartNum] as [Part1_PartNum], [Part1].[PartDescription] as [Part1_PartDescription], [Part1].[TypeCode] as [Part1_TypeCode],
[RunningTotal].[Calculated_RunningTotal] as [Calculated_RunningTotal], [CalcDate1].[Calculated_Date] as [Calculated_Date],
--select Part1.PartNum, count(*)
inner join Erp.PartCost as PartCost on Part1.Company = PartCost.Company And Part1.PartNum = PartCost.PartNum
inner join (select
And
inner join (select
And
--group by Part1.PartNum
