Thanks for the answer, this did exactly what I was looking for!
--- In vantage@yahoogroups.com, Steven Gotschall <sgotschall@...> wrote:
> This one also had me confussed at first. The Customer Part Maintenance does not have a search button like other Vantage maintenance screens, but if you use the search "Binoculars" icon, you can search the customer part table and load the ones you want to edit or delete.
> From: Mark Wagner <mjfw2003@...>
> To: vantage@yahoogroups.com
> Sent: Friday, May 15, 2009 11:02:18 AM
> Subject: Re: [Vantage] Re: How do I edit the Part Number Cross Reference Description
> Not sure, I've always been able to delete it from the list view
> --- On Fri, 5/15/09, Brad <bbuettner@generalfo rmulations. com> wrote:
> From: Brad <bbuettner@generalfo rmulations. com>
> Subject: [Vantage] Re: How do I edit the Part Number Cross Reference Description
> To: vantage@yahoogroups .com
> Date: Friday, May 15, 2009, 10:53 AM
> Yes, I have tried that. It does not allow you to delete any records only to add new ones.
> --- In vantage@yahoogroups .com, Mark Wagner <mjfw2003@ .> wrote:
> > Have you tried the customer part setup file under sales management/order management? You can delete the customer part record and add a new one there
> > --- On Fri, 5/15/09, Brad <bbuettner@ ..> wrote:
> > From: Brad <bbuettner@ ..>
> > Subject: [Vantage] How do I edit the Part Number Cross Reference Description
> > Date: Friday, May 15, 2009, 10:33 AM
> > I have a mismatch between the Part Desciption in the Part Master and the Customer Part Master. How do I edit the Customer Part Master records? The system only seems to let you add new ones not edit the existing records. I have tried editing this field in order entry but this does not seem to make the change permanent in the Customer Part file.
> > Thanks for the help!
